Re: Super A gasket set
Posted by Hugh MacKay on May 24, 2005 at 14:15:22 from (64.228.11.12):
In Reply to: Super A gasket set posted by Bill in VT on May 24, 2005 at 10:08:23:
Bill: On tractors with no water pump the main large fan belt just goes around crank and fan pullies. With the water pump there is a 3 pulley for the water pump just below the generator or alternator which ever you have. So main large fan belt goes around crank, fan and water pump pullies. Water pump bolts right to block, thus you have a very short hose from pump to rad at lower rad hook up.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
