Re: Farmall A Oil Filter
Posted by Jim Becker on May 24, 2005 at 18:08:24 from (71.96.32.242):
In Reply to: Farmall A Oil Filter posted by John Martin on May 24, 2005 at 12:43:49:
The A came with 2 different oil filters, even thought the engines were all basicly the same (C-113). A tall filter was used until mid-'44 and a shorter one later. Yours should have the shorter one, whatever number it is. The catch is that they can be changed from one size to the other by just changing the canister and bolt. You really need to look at the tractor to be sure which it is.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
