Re: Oil leak on rear end?
Posted by Larry in CO on May 24, 2005 at 21:31:51 from (32.97.110.142):
In Reply to: Oil leak on rear end? posted by Andy in Ohio on May 24, 2005 at 15:06:02:
You can probably do it the way Ronald suggests, but I did it a different way. It will take a little longer and require some nerves and a lot of cribbing, plus a cherry picker (engine hoist) won't hurt either. Click the link below to see how I did it. Also, if you do the repair this way, you will be able to check out the inner bearings - I had one that was bad and it was a good time to replace it. Hope this helps. Larry
Post a Followup
