Re: 660D Hydraulic system failure
Posted by captaink on May 25, 2005 at 05:38:45 from (66.115.214.56):
In Reply to: 660D Hydraulic system failure posted by Justin Imhof on May 24, 2005 at 20:41:28:
Did they work before it was parked? Does the PTO run? If the PTO doesn’t run then it is probably the independent PTO drive tube stripped out of the hub in the pressure plate. If the PTO does run then you either have hydraulic pump or supply problems.
Post a Followup
