Re: SMTA points and power steering??
Posted by El Toro on May 25, 2005 at 06:11:18 from (205.188.117.138):
In Reply to: SMTA points and power steering?? posted by Todd L on May 25, 2005 at 05:50:52:
NAPA should have points and a condenser for your tractor and your Case/IH dealer too. The Borg Warner P/N for points is HS4. Hal
Your PS may need to be bled to remove the air.
Post a Followup
