Re: 44 H all fuel
Posted by CNKS on May 25, 2005 at 08:18:02 from (204.249.178.138):
In Reply to: 44 H all fuel posted by Wild Bill on May 25, 2005 at 08:08:28:
Depends on whether it has a kerosene or distillate engine. Distillate is no longer available, some people use kerosene as a demonstration or out of curiousity. On a practicle basis just use gasoline. The small gasoline tank was used to start the tractor, which was then run until hot, at which time it was switched over to the other fuel. Your tractor will run just fine on gas. I don't think it will run on diesel -- even if it does you still don't have a true "compression firing" diesel.
Post a Followup
