300 u starter
Posted by Joe Kimbriel on May 25, 2005 at 11:14:24 from (136.200.52.33):
Got the old IH 300 U back together and tried to crank the engine over using 12v on 6v starter. I heard many folks do this. Engine would not crank until I removed the plugs then is spun fairly decent. I removed the starter and cleaned all connections, brushes and inspected the windings. The thing didn’t look bad, but still no luck cranking the engine over with compression. Has anyone ever towed a tractor to see if the engine would start before investing any more money in the thing?
Post a Followup
