Re: H Broken Rod
Posted by Janicholson on May 25, 2005 at 13:09:27 from (199.17.6.175):
In Reply to: Re: H Broken Rod posted by RustyFarmall on May 25, 2005 at 08:25:35:
My two cents as follows: If the break in the block is moderate in size (might pass a chicken egg, but not a baseball) I would repair the break by grinding the opening so that the egdes are smooth. And I would limit all cracks by using a 1/16 inch drill to put hole at there extreeme end. (this limits "stress concentration") I would use a 1/4" plate bent to match the block if curved there. and I would drill and tap holes to bolt the "patch" inspection plate on the block. Remember to use tap drill size for the threads, and clearance size for the plate. 1/4X20 is a good size. no more than 1.5 inches between bolts! A cork gasket made from 1/16 thick sheet, and non hardening permatex sealer will make a nice job. At least in looks compared to a welded on plate. The pan should be off to clean and polish up the rod journal, so cleaning chips should be easy. If the break is located in a place with attachment points for internal or external components, I would seriously consider a different block. Good luck JimN
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
