Re: M belt pulley seal
Posted by Randy SE-MN on May 26, 2005 at 11:58:16 from (206.9.216.42):
In Reply to: M belt pulley seal posted by Craig Thoricht on May 26, 2005 at 11:27:19:
The driven shaft and 3 bolt cover should come right out. Tap on the pulley flange evenly around. You might have to pry the 3 bolt cover away from the main body. place a drain tub under the flange because a quart of lube will fall to the floor. Good luck.
Post a Followup
