Re: md magneto
Posted by El Toro on May 26, 2005 at 17:16:14 from (64.12.117.13):
In Reply to: md magneto posted by jim in ny on May 26, 2005 at 05:12:58:
If you ever decide to have that mag rebuilt you
need to see where the rotor is pointing and make a note of it. I would write it on paper too.
This is so you don't have to crank the engine over to the compression stroke when No1 piston is at TDC. Once you have noted the rotor position
and have removed the mag don't crank or turn the engine over. Remove the battery ground until you get mag back and rotate the rotor to the same position as when you removed the mag. Make sure your rotor is in the same position before attempting a start. Hal
Post a Followup
