Re: IH 454 trouble
Posted by JB2 on May 27, 2005 at 19:25:24 from (69.196.154.214):
In Reply to: Re: IH 454 trouble posted by joe/pa on May 27, 2005 at 18:35:01:
Hi Joe, the squealling is not a good noise.
Squealling usually indicates a bearing lacking lubrication and about to sieze. According to the I&T shop manual, the speed transmission main shaft is always turning when the clutch is released. The speed transmission consists of 1 main shaft and a countershaft but the main shaft is split into 2 pieces, the input part at the front and the output part at the back. The rear of the input shaft fits inside the front of the output shaft.
So if range transmission is between gears and clutch is released then only the main shaft and possibly the coutershaft should be turning.
To access the top cover of the speed transmission
all the parts from the battery box, steering, dash and etc. have to be removed. To repair the tractor has to be split at clutch housing and it is not clear from the manual if it has to be split again between at range transmission.
Good luck
JB2
Post a Followup
Today's Featured Article - A Belt Pulley? Really Doing Something? - by Chris Pratt. Belt Pulleys! Most of us conjure up a picture of a massive thresher with a wide belt lazily arching to a tractor 35 feet away throwing a cloud of dust, straw and grain, and while nostalgic, not too practical a method of using our tractors. While this may have been the bread and butter of the belt work in the past (since this is what made the money on many farms), the smaller tasks may have been and still can be its real claim to fame. The thresher would bring in the harvest (and income) once a y ... [Read Article]
