Re: cuts out....gas?
Posted by FRANK on May 28, 2005 at 12:49:24 from (209.240.205.63):
In Reply to: Re: cuts out....gas? posted by ToddH on May 28, 2005 at 12:35:24:
I ASSUME YOU HAVE A DIST., AND NOT A MAG. IF SO, FOR NO MORE THAT IT COSTS, DO A COMPLETE TUNE UP. POINTS, PLUGS, COND.,AND COIL. IF YOU ARE GETTING THE GAS FROM THE CARB AS YOU SAY, I,M BETTING SHE RUNS O.K.GOOD LUCK, FRANK. P.S.LET US KNOW THE OUTCOME
Post a Followup
