Re: cuts out....gas?
Posted by Nat on May 28, 2005 at 14:21:23 from (24.93.8.168):
In Reply to: Re: cuts out....gas? posted by ToddH on May 28, 2005 at 12:35:24:
If I was saying that, I would've said that, but I didn't.
I clearly said it's a fuel flow problem.
I was also explaining WHY a tractor could have a bad coil or condensor, and still run.
Post a Followup
