wide tread Super C ??
Posted by Turk on May 29, 2005 at 08:23:09 from (206.222.209.114):
Hi Everybody, I put a Super C together this year using two dead ones. After it was assembled one of my friends called and asked about the rear axles housings, they are wider than any of the C's around here by about five inches. I had not noticed, but I did think it was odd that I could not get it on 30 inch rows. A previous owner fed cattle with it and cut the axles to get closer to his bunks. Guy's book lists 88 and 100 inch axles, I am guessing this was 100. Also had a single front. Are these uncommon or just uncommon around here? I have the facilities to repair the axle shafts if it would be worthwhile, otherwise it will get the standard ones from the donor. This is the first C I have actually used and I can't imagine how I made it this long without one. I made a FH to 3pt. adapter for it, and my two 8n's have not moved since. Very versatile and capable little tractor. What do you think? Bill
Post a Followup
