Cleaning Tube on Cub
Posted by Roger WI on May 30, 2005 at 18:30:26 from (69.58.150.133):
On my Farmall Cub, I went to blow air through the tube that connects between the block and the air cleaner and it is plugged. I tried filling it with carburator cleaner, letting it soak, and then using compressed air, but wouldn't clean it out. I tried a wire, but couldn't get the wire to go around the corner enough to clean it out. Do I have to make a new tube or does someone have a trick to clean these? I have always been able to eventually clean them out before. Roger
Post a Followup
