Re: 3 Wire Alternator: Terminal Identification
Posted by farmallhal on May 30, 2005 at 19:11:11 from (64.24.35.16):
In Reply to: 3 Wire Alternator: Terminal Identification posted by PaulW_NJ on May 30, 2005 at 17:26:59:
Paul, when I converted my H to 12 volt negative ground with a Hitachi alternator I was faced with the same dilemma. Bob Melville provided the answer to me and I believe it applies to you as well. The "L" is for the circuit with the light, resistor or diode installed back to the ignition switch and is labeled "1" in his diagram and the other spade lug which was labeled "S" on the Hitachi is for Sense and was the same as the "2" terminal in his diagrams for the jumper back to the Bat. terminal. I used insulated female spades on my conversion to prevent any possibility of a short between the two spades on the alternator. I'm betting this will work for you as well. Bob may see your post and may answer with his technical knowledge also.
Post a Followup
