Re: CUB CUTTING OUT
Posted by Nat on May 31, 2005 at 08:48:54 from (64.80.110.40):
In Reply to: Re: CUB CUTTING OUT posted by NICK D on May 31, 2005 at 03:42:37:
That's because you weren't using the little tube. The new cans of WD40 put out a fine, wide spray without the little tube, not the directed stream you need to overcome the fan.
Post a Followup
