Re: HOW DO I START THIS TRACTOR ?
Posted by Nebraska Cowman on June 01, 2005 at 18:39:46 from (65.162.146.175):
In Reply to: Re: HOW DO I START THIS TRACTOR ? posted by Rick in Vermont on June 01, 2005 at 17:49:55:
It sounds like you have the rare early style ground switch on your magneto. Yes it is a cable like a lawnmower. But i think the switch works the same as the later style, pull to run, push to stop.
Post a Followup
