Re: HOW DO I START THIS TRACTOR ?
Posted by jnewark on June 02, 2005 at 04:41:16 from (167.21.1.230):
In Reply to: HOW DO I START THIS TRACTOR ? posted by Rick in Vermont on June 01, 2005 at 17:35:43:
the pull you described is a ground on the mag. you have to pull it out and hold it out to stop the motor, push it back in and she will fire..
jack
Post a Followup
