Re: Towing a 400 with power steering in parade?
Posted by Bob M on June 02, 2005 at 06:06:45 from (151.190.254.106):
In Reply to: Towing a 400 with power steering in parade? posted by migraine on June 01, 2005 at 22:00:58:
I've used a towbar bolted to the bolster to tow my Charlynn PS-equipped Super M without any problems.
As long as the engine is not running the Charlynn torque motor is just sorta "along for the ride" - steering shaft movement from the front end is transmitted easily through it to the steering wheel. Gotta think your 400 will work the same.
Try bolting the towbar in place then use it to steer the front wheels by hand. If you can turn the bolster at all you should be fine.
Try to take and post a photo of your train setup - it sounds pretty slick! (Punch below for a shot of a train at the '03 RPR in Bloomsburg PA)
Post a Followup
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
