Re: Farmall valve timing
Posted by captaink on June 02, 2005 at 08:34:23 from (66.115.214.56):
In Reply to: Farmall valve timing posted by RobPA on June 01, 2005 at 18:05:37:
You can not put the flywheel on wrong, the dowel pin and bolt pattern prevent that. If the cam is timed wrong it may or may not run, if it does, not very well depending on how far the cam is out of time. Others have already given you good ideas to consider.
Post a Followup
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
