Re: 240 utility hydraulics problem
Posted by genep on June 02, 2005 at 09:52:38 from (216.96.6.8):
In Reply to: 240 utility hydraulics problem posted by Marvin M on June 02, 2005 at 06:28:44:
I had a 340 and, if the 240 is similar, the hydraulic oil is the same as the transmission oil. The pick up tube was on the right side of the transmission and if the tractor got somewhat unlevel the oil would flow away from the pick up, allowing the pump to suck air. I would have to get the tractor back reasonably level and crack a fitting (with the tractor running) on the pressure side so the pump could reprime itself. Your mileage may vary on a 240.
Post a Followup
