cub axle/planter gear confusion..help,please!
Posted by KevinH on June 02, 2005 at 16:13:48 from (64.139.245.186):
I got a set of planters for the cub...that"s old news. I went to put the gear on the rear axle and the axle housings had been switched sometime due to busted out bolt holes.Problem is now the axle that the gear goes on is on the wrong side. Do I have to switch axles or is there something I"m just not seeing? If I have to switch axles, how do I go about it? I"m pretty good on the engines, but I"ve never been into the axles on these cubs. Thanks for any help, Kevin
Post a Followup
