Re: Farmall 756 ignition key switch question
Posted by K.B.-826 on June 02, 2005 at 16:42:35 from (68.115.102.134):
In Reply to: Farmall 756 ignition key switch question posted by Mike Persson on June 02, 2005 at 06:08:43:
Sounds dangerous. The only things that went through the key switch from the factory were the idiot lights, the fuel guage, and the igintion. Your Case-IH dealer should be more than happy to make you a photocopy of the wiring diagram. Like tractor vet said, $20 spent on on relays and breakers is well worth it. Get the cab on it's own relay controlled by the key switch and then add a few breakers here and there. Make sure your relay is good for at least 30 amps.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
