Re: Which rims would you get?
Posted by Hugh MacKay on June 03, 2005 at 02:30:59 from (216.208.58.176):
In Reply to: Which rims would you get? posted by Lance R. on June 02, 2005 at 19:22:55:
Lance: I take it the 15" rim is not available. Where are you situated? I know there are 15" rims floating around here. I've seen several sets at auctions this spring. One interesting note, they all had yellow paint, but the same double mounting ring as on your 560. If your close enough and you wish, I can ask a few questions. The rims I saw were in excellent condition. Most of them had decent tires as well.
Another item you might check out is 16" rims and use 18.4 tires. I saw a set on a 656 once, not a lot higher than the 16.9 I had on my tractor.
Post a Followup
