Re: Difficult Shifting
Posted by captaink on June 03, 2005 at 06:35:54 from (66.115.214.56):
In Reply to: Difficult Shifting posted by PAULIH300 on June 02, 2005 at 18:50:13:
Good posts on the TA and the need to get it adjusted correctly. What happens when it is not adjusted correctly is the direct clutch on the TA planetary doesn’t fully disengage preventing the planetary unit from rotating and the sprag clutch (one way on the back of the planetary unit) prevents it from rotating one way, so any pressure between the gears in the transmission is not relieved. BUT you noted that you have a hang up with the TA in either position which leads to other possibilities also. I have personally seen where the original full faced fiber clutch disk (main clutch) has been replaced with a metallic button clutch disk. These button clutches were sold on the premise that they reduced the heat created by a slipping fiber disk and that they could handle higher horsepower better in hard use situations like under loaders. What I have noted is that these clutch disks are harder than the flywheels and pressure plates and wear a curve into the pressure plate and flywheel surfaces. Tearing the clutch apart and installing a new disk, pressure plate, and resurfacing the flywheel will cure the issues for a while unless you put a full faced fiber clutch back in. I have theorized that this curved area causes the clutch to “drag” when released and even may get “sucked” against either the pressure plate or flywheel. Some have had some reduction in this phenomenon by grinding an X shape in each pad on the clutch disk. I usually put up with poor shifting until I have the tractor apart for another reason, then I reface the flywheel, replace the pressure plate and the clutch disk with the original style full faced fiber disk. This seems to offer the best solution when adjusting the TA won’t take care of this problem. My nickels worth.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
