Re: Farmall valve timing
Posted by El Toro on June 03, 2005 at 08:50:11 from (205.188.113.42):
In Reply to: Farmall valve timing posted by RobPA on June 01, 2005 at 18:05:37:
Did you get the tractor to start? If not you need to pull No1 plug and bring that piston up on the compression stroke to TDC. When you feel
compression against your thumb look for that timing mark on the flywheel. It's easier to see
if you chalk the timing mark. Keep rotating engine until that mark is aligned with the indicator. Then look at the rotor to see where
it is pointing. Should be at No1 plug wire.
Are you in PA? I'm in MD. Hal
PS: Both valves on No1 are closed if the valve timing is ok. If the rotor isn't pointing to No1
your distributor probably needs to be removed and
set at No1 position and reinstalled.
Post a Followup
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
