Re: 1951 C
Posted by Gary_N_WV on June 03, 2005 at 10:20:44 from (129.71.207.144):
In Reply to: 1951 C posted by Allen in TN on June 03, 2005 at 08:46:49:
Allen,
The bent push rod can be straightened and used as long as there is no damage to the ends and it's not bent to a point that it is just junk.
You may find a rod from someone here or you can check a tractor salvage yard or maybe you can find one on Ebay if yours isn't repairable.
You need to soak the valve stems with a solvent like WD 40 to loosen any rust etc that would make the valves stick.
You need to look for the reason the rod bent IE; stuck valve or rocker too loose etc.
Yes, the engines are pretty easy to work on and there are many-many guys on this forum to help you along.
When you say you can turn the engine over on the upper pulley, I assume the bottom pulley is turning too ?
The upper pulley is just for the cooling fan and the lower one is the important one to be able to turn.
Gary
Post a Followup
