Re: governor speed
Posted by CNKS on June 03, 2005 at 17:30:17 from (204.249.178.138):
In Reply to: governor speed posted by Carlton on June 02, 2005 at 20:41:25:
Max idle speed on the Super H is 1815, rated rpm is 1650. Since the 300 rated rpm is 1750, I would guess the max idle speed to be around 1900+. If it has a serial tag, it will say on it.
Post a Followup
