Re: Looking for 560 2pt lift arms attachments for
Posted by Lance R. on June 03, 2005 at 19:52:14 from (65.166.133.43):
In Reply to: Re: Looking for 560 2pt lift arms attachments for posted by Available here on June 03, 2005 at 16:01:39:
The only problem with these lift arms is that they do not curve up fron the two point hitch. These are the kind I have on my 560 and I can't get the rotary hoe or cultivator to lift but maybe 4 - 5 inches off the ground. There is suppose to be a set designed for the older 2 point hitches (Pre 656) that corrects this problem.
Post a Followup
