Farmall Tractors Discussion Board
Re: Hy - Tran? or 90 wt. For Transmission??
Posted by Dave Bowers on December 14, 1999 at 08:55:55 from (205.188.198.179):
In Reply to: Hy - Tran? or 90 wt. For Transmission?? posted by Farmall Newbie on December 13, 1999 at 08:59:48:
I'm glad someone else had this problem. I rebuilt a 350D and put the usual 85-140 oil. The tractor would lock up, at first I thought about the diesel engine. But it would start back up right away. THEN I found out about the memo and the hydraulic type oil. I changed the oil and the tractor has not locked up since.
Dave and Mary Bowers Phx, AZ
Post A Followup
: Re: Re: Hy - Tran? or 90 wt. For Transmission??
