Re: hydrolic lift?
Posted by brattin1103 on June 04, 2005 at 08:00:15 from (207.200.116.203):
In Reply to: Re: hydrolic lift? posted by Jim Becker on June 03, 2005 at 18:50:16:
here are the numbers
under #1 plug 4
251069r1
hydrolic unit under gas tank 354352r1
plate on gear box 9-2-47
on rear belt drive under seat 9090d
hydrolic sending unit by steering column 05-12185
cast into block sample in middle behind distributor cap or close to
pic added on pic post did not know how to put it here
Post a Followup
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
