Re: sweet corn plates
Posted by Jim Becker on June 05, 2005 at 10:51:00 from (71.96.20.180):
In Reply to: Re: sweet corn plates posted by Hugh MacKay on June 05, 2005 at 02:47:32:
I never heard of the rubber band trick but it sounds like a good idea.
One other thing you can do as a final check is "test planting" on a hard surface (like the driveway). You should end up with a row of seeds laying on top of the ground that you can check for skips and broken seed. You need to run this test at the same speed you intend to run in the field. Sometimes you won't get skips at slow speed even if it skips at higher speed.
Post a Followup
