Re: '47 M water pump questions--possibly solved?
Posted by El Toro on June 05, 2005 at 17:03:46 from (205.188.117.138):
In Reply to: Re: '47 M water pump questions--possibly solved? posted by Mediocre Mechanic on June 05, 2005 at 13:19:12:
Our local radiator shop said if you have a overheating problem and the thermostat is ok you should hold your hand against the radiator to see if if feels hot. If it doesn't the radiator cores are probably plugged and needs to be rodded because the water isn't circulating through the radiator.
Hal
Post a Followup
