706 WOES
Posted by borde on June 06, 2005 at 05:05:54 from (65.0.6.111):
got a 706 home in buckets
put it together finaly
keep finding new problems 1 in praticular is
has any one found a way to get the frozwn hitch pins out from the draft control on the lower lift arms
after taking the uper 3 point plate off could it be possible to reach in and undo the draft senstng
arm U bolt loose and then pull out the lower lift arm shaft tro save from taking out the ppower take off and then replaceing shaft without the sensing arm , I dont need draft control anyway
got it looking good but after using found another problem someone replaced left rear final drive and it has a little shakey when backing up could it be bad bearing clearince in bull pinion or maybe a worn bearing trying to stack
paint dont cure all
thanks
ed
Post a Followup
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
