Re: Help- IH 140 has no spark.
Posted by Jim in NC on June 06, 2005 at 10:49:37 from (172.145.59.247):
In Reply to: Help- IH 140 has no spark. posted by seacern on June 06, 2005 at 10:33:09:
Use an ohm meter to see if you have current to the distributer with the switch on. If so, then you may have a points or condenser issue. I have had a wire to break behind the battery and the switch area of my 1961 140 that kept mine from starting and running once. The points could be shorted to ground at the distributer also. My brother has a super A that has to have the points filed sometimes if it sets for a long period. If only he would change them. Good luck with your tractor.
Post a Followup
