Re: 3pt. mowers on SH?
Posted by P Backus on June 06, 2005 at 20:44:18 from (69.128.32.4):
In Reply to: 3pt. mowers on SH? posted by Eric NW Iowa on June 06, 2005 at 07:58:13:
I've been thinking of doing something like that on my F-12. It
would be the same concept, I just haven't taken the time. What I
had in mind was to get a pair of the category 1 lower links from
the local farm supply store (although you could make something
up too). I would mount them above the existing U-shaped
drawbar on the Farmall. That way the weight of the mower is
held by the drawbar, but it allows the links to float upward so
that the weight of the tractor doesn't wind up on the mower
when you go through a ditch, leaving the wheels spinning.
Depending on how fancy you want
to be, you could make it adjustable so you can change the
height of the implement. Sorry if this seems cryptic- it's clear as
a bell in my head. I can explain more if you'd like. It would be a
fairly simple project I think. Hope this helps.
Paul
Post a Followup
