Re: Timing Magneto on a Farmall Regular
Posted by Jeff Wenner on June 07, 2005 at 11:37:32 from (164.156.153.254):
In Reply to: Timing Magneto on a Farmall Regular posted by Lunatic Fringe on June 07, 2005 at 10:55:08:
If you have the original E4A mag on it, advance your timing lever all the way, take the two 1/4" bolts out of the mag coupling, with the # 1 cylinder on top dead center, and the rotor near the #1 distributer brush, turn just the magneto untill the points just open up. Look at the coupling and find the two holes the line up the best and put the bolts back in. If you have a newer F4 mag it works pretty much the same but you have to stick a wire or something in and disengage the automatic impulse.
Post a Followup
