Re: C Piston Sleeves Out!
Posted by El Toro on June 07, 2005 at 12:33:50 from (152.163.101.13):
In Reply to: Re: C Piston Sleeves Out! posted by Pharmall on June 07, 2005 at 10:47:19:
Use 3/4 " plate if you don't think 1/2" plate will
withstand the load. You will need the cutout piece 9X9 or 10X10. When you get a chance get me the bore of the block at the bottom near where the sleeves rest. I think it's somewhere around
3.4". When you 're ready to reinstall the damper pulley put it in an oven and heat it up. 300 degrees should be enough. Hal
Post a Followup
