El Toro - Bore Measurement
Posted by Pharmall on June 07, 2005 at 19:31:05 from (68.9.106.167):
That 3.300" dimension was measured directly on the engine
block, right where the o-ring groove is located. Got the same
dimension on all four cylinders, but I don't have a tool or gauge
blocks to measure the depth of the o-ring groove. The sleeves
start out at 3.270" at the bottom, and work their way up to
3.310, where they radius to the thick wall part of the sleeve.
Looks like the sleeve diameter is about 3.280"-3.290" where it
would contact the o-ring, so it smushes the o-ring pretty hard.
Cheers, Jeff
Post a Followup
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
