Re: Farmall BN overheating
Posted by gene b on June 07, 2005 at 20:19:39 from (66.43.221.243):
In Reply to: Farmall BN overheating posted by RobertPA on June 07, 2005 at 18:18:12:
You should have flushed the block from bottom to clear the small holes at the base of the sleeves also using some compressed air. Lots of these blocks have some crud down at the bottom of the sleeves and are slowing down the flow of coolant. Is the overflow tube clear in the radiator. When you shut down the engine take a temp of the coolant it should not be over175 or so. Are the fins clean and was the fan belt tight enough. Have yet to see a radiator plugged inside problems are about always plugged in the block. There is no thermostat so that is not an issue. You can always add a water pump for a C all you need is a longer fan belt.Not hard to install.
Post a Followup
