Re: 140 Lift
Posted by scotty on June 09, 2005 at 04:43:21 from (199.231.49.128):
In Reply to: 140 Lift posted by Avery on June 09, 2005 at 04:33:37:
Avery,
Sounds to me like your touch control may need a rebuild. You might start by buying the Touch Control manual from Binder Books for $7.95. It will take you through a series of tests to establish if your unit indeed needs to be rebuilt. Worst cas senario would be a rebuild kit from your Case IH dealer to the tune of about $100. It sounds to be like your hydraulic fluid is leaking by your main cylinder o-rings.
scotty
Post a Followup
