Farmall Tractors Discussion Board
Re: Re: Re: F-450 TA linkage
Posted by RickB. on December 14, 1999 at 16:33:52 from (205.231.148.9):
In Reply to: Re: Re: F-450 TA linkage posted by IHank on December 13, 1999 at 17:00:53:
His message is in the name field; the linkage has been removed. The typical reason for this was because the low side of the TA is inoperative. This will require a double split of your tractor & a minimum of $400 in parts alone to repair properly, as well as whatever else is found "while you are in there" and replacing the missing linkage parts. Or, you can run it in direct drive and forget it ever had a TA.
Post A Followup
: Re: Re: Re: Re: F-450 TA linkage
