Farmall C Hydraulics Leaking
Posted by scooterxs on April 06, 2009 at 12:58:15 from (138.163.0.41):
My C keeps dumping fluid into the crankcase. I noticed when i removed the pump that the seal was pushed into the drive gear. I replaced only to have it happen again so this time i punched the block around the seal hole so that it would help hold seal in place. Now it just blows out the lip on the seal.
My question is what could be causing this i'm thinking to much pressure but dont know what could be causing it. The shaft is worn slighty but didnt look like enough to be causing the problem this quickly. Within 10mins of running it dumps all fluid to where it wont lift anything. Any input would be greatly appreciated. Thanks
