Re: Cub cadet mowers
Posted by El Toro on June 10, 2005 at 07:24:41 from (205.188.117.73):
In Reply to: Cub cadet mowers posted by Farmin Red on June 10, 2005 at 06:16:03:
I worked with a man that was sharpening his mower blades and I happened to pick up one of the blades
and said these blades don't need any sharpening.
He said his grass was always white looking after he mowed. I looked at the blades again and the green from the grass was on the wrong edge. I said you've been putting these blades on in the wrong direction. The sharp edge needs to rotate
in the direction of the spindles. He never had
any problems after that.
If the grass is tall you may need to select a lower gear. Hal
Post a Followup
