Re: Cub cadet mowers
Posted by Dr.EVIL on June 10, 2005 at 10:02:49 from (216.136.115.250):
In Reply to: Cub cadet mowers posted by Farmin Red on June 10, 2005 at 06:16:03:
Everyone else has given good suggestiosn. The 44 & 50" decks aer THE BEST IH ever made. Take the decks off both tractors and prop them up against a wall and spin the blades so the end of one blade is right next to the other.... make sure they are close to being in the same plane.... like within 1/16" to 3/32". Spin ONLY ONE blade and check again.... Spin other blade & check again... Now switch to the other end of the deck & check again. Make sure the spindle bearings are not loose & wobbly... If Your blades do not pass the tests above FIX whatever is causing them to fail. Could be a bent blade, bend mower housing causing a spindle to be cocked. When You re-attach the mowers You should have a threaded hanger on one side... and on the front, Eyebolts. Take a small block, 2X4 works and make sure Your mower hangs level off the tractor by sliding the block around on a smooth FLAT concrete floor. When You mow You shouldn't be on wet grass, or driving faster than about 1/3 to 1/2 as fast as Your Hydros let you. You Can't mow wide open on the hydro! Actually for just mowing grass a 129 (I have one too) should run a 50" deck slowly very well. Also check "ihcubcadet.com" the setup above is one of their Frequently Asked Questions.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
