Re: Hyd oil getting very hot - why?
Posted by Haas on June 11, 2005 at 06:51:19 from (12.65.6.28):
In Reply to: Hyd oil getting very hot - why? posted by fixitforfree on June 10, 2005 at 22:15:20:
As Nat said, maybe the hydraulic system is under load (pressure) all the time for some reason. This could be a defective control valve or some other restriction, causing the system to pressure all the time. Does the tractor engine sound like it is under load all the time which would happen if the hydraulics are pressurized. The pump working under pressure will quickly heat the hydraulic fluid.
Post a Followup
