Re: Farmall A Crankshaft
Posted by El Toro on June 12, 2005 at 08:28:06 from (64.12.117.13):
In Reply to: Re: Farmall A Crankshaft posted by Matt on June 11, 2005 at 09:44:16:
That's an easy job to pull that engine. When I restored an A, I removed the front wheel assembly
from the engine and rolled it out from the engine.
This made it easier during reassemble. Mark all your wires that you remove. Pull the radiator
and support the rear of the tractor so it doesn't tilt backwards. Use an engine crane so you can pull the engine away after unbolting. Support the front of tractor so it doesn't fall forward.
Be safe when doing this. You can rent those engine cranes, sometimes called cherry pickers.
You can pull the cylinder head and damper pulley
prior to pulling the engine. Hal
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
