Re: My 154 Cub-Loboy won't run at 800 RPM??
Posted by El Toro on June 13, 2005 at 04:02:18 from (205.188.117.73):
In Reply to: My 154 Cub-Loboy won't run at 800 RPM?? posted by John in Ct on June 12, 2005 at 18:30:50:
I think your engine is running too lean since you said you had to choke the engine to restart it.
It may have some dirt in the high speed jet. I would check that valve clearance to make sure they aren't too tight. Float setting is 1-13/32"
according to my IH manual. The float could be rubbing the wall of the carburetor and wouldn't let the bowl fill to the correct level. Has to be something minor since it idles ok. Will it accelerate to full throttle with the choke partially on? If it does a good indication of not getting enough fuel. Hal
Post a Followup
