Re: tractor keeps dieing on me
Posted by old on June 13, 2005 at 11:01:00 from (207.69.138.202):
In Reply to: tractor keeps dieing on me posted by rick o on June 13, 2005 at 10:38:56:
Could be a fuel problem as the other guy says, pull the drain plug at the bottom of the carb. You should get a good flow from it, say about half the size of a pencel. If you don't the you have a clogged fuel system. If you get a good flow you may have a problem with the condenser, or ignition switch.
Post a Followup
